Activity Forums Adobe After Effects Expressions How to detect multiple OK buttons in Script UI dialogue box
  • How to detect multiple OK buttons in Script UI dialogue box
    Posted by Reuben Lara on October 17, 2018 at 12:37 am
    In the code below, I can’t seem to target which button was pressed. Both “Option 1” and “Option 2” should behave like OK buttons (do some code and close the window). What am I doing wrong? Thanks!
    var myWindow = new Window ("dialog");
    myWindow.add ('statictext', undefined, 'Mode:', {multiline: false});
    // some more window input options
    myWindow.add ("button", undefined, "Option 1", {name: "ok"});
    myWindow.add ("button", undefined, "Option 2", {name: "ok"});
    myWindow.add ("button", undefined, "CANCEL", {name: "cancel"});
    if (myWindow.show () == 0) {
    alert("You chose Option 1");
    //execute some code and close the window
    if(myWindow.show () == 1){
    alert("You chose Option 2");
    if(myWindow.show () == 2){
    alert("You chose Cancel");
    exit ();
    Reuben Lara replied 7 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 17, 2018 at 6:12 am
    I’m not sure how it’s supposed to work, but it seems like you could set up a unique onClick function for each button, or direct them all to the same function, but have unique names for each button (like “ok1″,”ok2”, and “cancel”) so the function can detect which button was clicked:
    function button_click(){
    if (this.name == "cancel"){
    // do stuff
    }else{
    // do other stuff
    Dan
  • Reuben Lara
    October 17, 2018 at 7:36 pm
    Thanks for the ideas. Tried them and they didn’t respond as expected. In the end, it turns out ScriptUI dialogues can only have one default “OK” button and one default “cancel” button where the window returns either “1” or “0” for OK and Cancel respectively. Script UI detects if the “name” is “ok” or “cancel” to give those buttons default functionality. If multiple buttons have a “name” of “ok”, then only the first one is recognized. So, to add additional buttons that behave like the OK button (i.e. do some code and close the window), see below:
    var additionalOKbutton = myWindow.add ("button", undefined, "Option 1", {name: "option01"});
    additionalOKbutton.onClick = function (){
    //execute some code
    //close window
    myWindow.close();
    if (myWindow.show () == 1) {
    //execute some code
    //window closes automatically
    }else{
    //execute some code
    exit ();
