Activity Forums Adobe Premiere Pro How to delete cut segment from clip without unlinking?
  • How to delete cut segment from clip without unlinking?
    Posted by Evan b. Peters on September 26, 2017 at 3:22 am
    Hello all, thanks for the help, as always.
    Sorry if this seems obvious, but I can’t figure it out.
    I have taken an audio track and synced it with the existing audio from the video clip, I’ve done this by linking them. The problem is, when I make a cut and go to delete the piece that I just cut, it highlights the rest of the clip that it is linked to. If I delete it, I have to ctrl+l to unilnk, delete and then ctrl+l again to link them back together. This can’t be right.
    Is there a way to make anything I cut automatically separate itself from the other clip while simultaneously linking itself together?
    I hope this makes sense.
    Thank you!
    EBP
    Evan b. Peters replied 8 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
