More than one way to skin a cat.
1. Lock all the video layers, by holding shift and selecting the lock on one of the video tracks. (They all lock). Then Select all and only the audio will be selected then hit delete. Hold shift and click on the locked icon in one of the video clips and you’re back again, but without any audio. 🙂
2. Zoom all the way out with the \ key. Hold the Alt Key and drag and box (marquee) selection across the audio portion of the clips. This will only select what your box has inside it. Once all the audio clips are selected hit delete.
I don’t think there is any faster way than these two methods. Which should only take about 5secs away from your life, which I’m sure you won’t miss.
– Jon Barrie 🙂
Jon Barrie
aJBprods
Jon’s YouTube Tutorial Page
follow Jon with twitter
