Activity Forums Adobe Premiere Pro How to delete all files in project that are not on timeline?
  • How to delete all files in project that are not on timeline?
    Posted by Frank Manno on March 12, 2009 at 3:06 am
    I have a lot of files in my project window that are not used in my timeline and are not needed.
    Is there a way I can delete all files that are not associated with timeline clips?
    -Frankie
    Frank Manno replied 17 years, 5 months ago 3 Members · 3 Replies
  • Mike Velte
    March 12, 2009 at 10:25 am
    If they are not there already, add “Video Usage” and “Audio usage” to the columns in the Project window. Sort that column by clicking on the name header, select the first blank usage clip and then shift click the last one and press the delete key.
  • Guy Kingston
    March 12, 2009 at 11:35 am
    Mike,
    Try:
    Project > Remove Unused
    Good luck,
    Guy
  • Frank Manno
    March 12, 2009 at 2:05 pm
    Thanks Mike and everyone.
    I’m starting to like Premiere. There always seems to be a way to do something 🙂
    Somethign else I discovered, if I have keyframes on a clip and want to do a slip edit on that clip, it also moves the keyframes. (In my case the keyframes are performing a fade to black).
    Is it possible to do a slip edit without the keyframes moving?
    -Frankie
