Activity Forums Adobe After Effects How to cycle through a set of strings in after effects
  • How to cycle through a set of strings in after effects
    Posted by Peter Bentley on February 25, 2016 at 6:37 pm
    My apologies to the internet for duplication, but I realized the Cow might be a better place for this question than the Adobe Forums.
    I’ve learned how to cycle a number (say from 1 to 100) within a text field using an expression and the slider effect. Is there a similar way to take a group of strings, maybe defined in a text document or Excel file, and then have those strings cycle through a text field in After Effects? Specifically, I’m thinking…
  • Create a text field in After Effects
  • Define various text strings somewhere (text document? Excel file? Somewhere in After Effects?) For example: String 1: “Fallacies do not cease to be fallacies because they become fashions.” String 2: “An adventure is only an inconvenience rightly considered. An inconvenience is only an adventure wrongly considered.” Etc., on down to say, 20 strings.
  • Have a way to cycle those text strings (read: replace in place) from 1–20 when I set keyframes.
  • Anyone know how to do something like this? Thanks in advance.
Peter Bentley replied 10 years, 6 months ago 2 Members · 2 Replies
    • Michael Szalapski
      February 25, 2016 at 9:27 pm
      Actually, it looks like you got some great advice over there! 🙂
      – The Great Szalam
      (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
    • Peter Bentley
      February 25, 2016 at 10:19 pm
      Yep. Thanks for your thoughts on that thread. I actually ended up creating a handful of layers in Illustrator that I cycle through by changing opacity in After Effects. But for this case Dave’s solution probably would have been the best: just create keyframes on the text field’s source text and cycle through in that way since text changes create hold keyframes.
