Activity Forums Apple Final Cut Pro Legacy How to crop (not ordinary “crop”), but cut away unwanted part of frame?
  • How to crop (not ordinary “crop”), but cut away unwanted part of frame?
    Posted by Simen Myrberget on May 13, 2010 at 11:33 am
    In Photoshop when you crop, you cut away the unwanted part of the picture and the number of pixels changes (less pixels). In Final Cut you get a black border around the cropped area. I would like to crop it and not have the black border around. The reason? A faulty chip with a green stripe on the edge of the footage……
    How to “crop” in the same way as in Photoshop in Final Cut Pro? I am using FCP 6 btw….
    Simen Myrberget replied 16 years, 4 months ago 3 Members · 4 Replies
  • Kim Rowley
    May 13, 2010 at 4:58 pm
    Either do as Dave suggests or you might want to check out
    https://www.digital-heaven.co.uk/dh_dropout
    which may be able to fix your faulty footage.
    Cheers1
    Dual 3 GHz Dual Core Intel, 4GB RAM, ATI Radeon X1900, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.0.6), OS X10.4.11
  • Simen Myrberget
    May 13, 2010 at 6:44 pm
    Thanks. That was a great tip and a very instructive video on the subject (plug in)!
    I still have much to learn ….. 🙂
  • Chris Tompkins
    May 13, 2010 at 6:57 pm
    If the plug-in doesn’t do it for you. Double up your video layer on track 1 and 2. Scale up only the layer on track one and blur it. Crop the problem edge out on track 2. Depending on the footage and the size of the crop, just an idea.
    Chris Tompkins
    Video Atlanta
  • Simen Myrberget
    May 15, 2010 at 9:59 am
    Thanks Chris! A creative suggestion. I will try it!
