Activity › Forums › Adobe After Effects › How to create water out of particles
Posted by Mballom on April 14, 2006 at 7:42 pmAnyone has a link toward a tutorial or can explain briefly the main steps involved when making water from particles?
Whatever water though let it be rain, drain, river flowing
Thank you
Satya Meka replied 18 years, 1 month ago 4 Members · 9 Replies -
Chris Smith
April 15, 2006 at 12:49 amWater is interesting because dependinon what form, there are completely different approaches. Rain is the easist because it’s just blurred streaks really. Particular has a preset for it.
Rivers can just be animated maps flowing down a flat plane like in a lot of games.
Water pouring in a glass is best done with metaballs or blobby surfaces. These are basically the same thing usually found in 3D packages. They have a clumping threshold so that when spherical balls get near each other, they clump together, How you set this clumping and the shader you assign to them makes them seem like water, mud, coke, whatever.
Chris Smith
https://www.sugarfilmproduction.com -
Chris Smith
April 15, 2006 at 12:50 amAdditional note:
Things like sprays and fountains seem to look best using Sprites. If you’ve ever played with Particle Illusion or Combustion you’ll see the presets look pretty bang on. It’s a bunch of sprites with small samples of mist.
Chris Smith
Mballom
April 15, 2006 at 3:53 amWow Thanks chris, now iam out of obscurity about water in AE and 3D packages 🙂
Ruediger Chmielus
April 17, 2006 at 10:21 amYou can create very realistic water with an combination of particles,vector blur and distortion effects.
I can send you some examples if you wish. -
Mballom
April 17, 2006 at 7:39 pm“I can send you some examples if you wish”
I surely and certainly do wish dear Rook, send them to me at this email
webmaster(at)centrobec(dot)caMany thanks
Ruediger Chmielus
April 18, 2006 at 11:06 ammballom,
I sent you a example of the created water. I am still digging through the project to give you an easy setup file…
Greetings, 😉 -
Ruediger Chmielus
April 18, 2006 at 1:20 pmFound something…I have sent it to your mail adress.
Enjoy! -
Satya Meka
July 25, 2008 at 11:35 pmhello,
Can you please send the water samples to me too? I really want to do something using it…and it will be really a great help if you send me those samples..an help me creating water in AE
my email address: bothana2003-at-gmail.com
thanks again
