Activity Forums Apple Motion How to create vector growth animation
  • How to create vector growth animation
    Posted by Ken Chan on September 17, 2007 at 8:38 am
    How do I create those animated vector graphics effects make popular in MTV promos, in which a graphic simulates growth with patterns reveals itself in different stages. Something similar to animated hand writing.
    I know it has something to do with animated mask, but I have tried, it is quite difficult to manage the mask to reveal different portion as intended.
    Is there an easier way that I do not know of?
    An example of the animation can be found at
    https://www.digitaljuice.com/products/products.asp?pid=329&tab=t3#tabs
    Please advise
    Ken
    Burt Hazard replied 19 years ago 2 Members · 1 Reply
  • Burt Hazard
    September 20, 2007 at 10:01 pm
    An animated mask would work (it’s a tried and true After Effects method).
    But yeah, in Motion there’s lots of ways to do stuff like this:
    2) With Replicators and Behaviors, if you have Motion 3, check out Library>Content>Flora>Branch 01 which uses Replicated shapes and the Sequence Replicator to animate ’em
    3) Shapes using Shape Behavior>Write On (in Motion 3, see Library>Content>Drawings>Ornament 01)
    4) Particle Emitters! (cool, huh?) by animating a Particle Emitter’s point of origin with a keyframed motion path (Inspector>Properties>Transform>Position) (in Motion 3, see Library>Content>Flora>Arabesque)
    5) With Motion 3, you could use the new Paint Stroke Tool as well as the new Sequence Paint Behavior (Shape>Sequence Paint) to reveal paint strokes over time
    5b) You could even create a animated mask with the Paint Stroke Tool (i.e., white paint strokes) and then utilize Stencil Luma, Stencil Alpha, etc. You can even edit the splines that make up the essentially vector “paint” strokes.
