Activity › Forums › Adobe Illustrator › How to Create this Look
  • How to Create this Look
    Posted by Erica Reichard on August 30, 2015 at 3:51 pm
    I cannot figure out how to create the loop in the letter B as shown in the example image attached. I want to create a similar look with it looped/threaded around the letter T in my case.
    Any suggestions?
    Vincent Rosati replied 11 years, 1 month ago 2 Members · 1 Reply
  • Vincent Rosati
    August 31, 2015 at 1:25 am
    Please see the attached project file…
    Delete Structure with Pathfinder project file >>
    The steps listed in the project file are:
    1
    Live text.
    2
    Type > Create Outlines.
    3
    Add a stroke and increase weight in Stroke palette
    4
    Select the stroked object and Object > Expand
    5
    Use the Group Select tool to select the outer edge of the stroke. Then Copy, Delete. Edit > Paste In Back.
    6
    Use the Group Select tool and shift-select the T and the back object. Then Effect > Pathfinder > Minus Back.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
