Activity Forums Apple Final Cut Pro Legacy how to create subtitles – srt/sub
  • how to create subtitles – srt/sub
    Posted by Himanshu Bhatnagar on September 4, 2010 at 3:46 pm
    Hello,
    Can anyone tell me the fastest way to create subtitles (.srt/.sub files) for a video? I also want to understand the basic difference .srt/.sub files. Sorry if this is the wrong forum to ask this query.
    I use final cut pro.
    Thanks in advance.
    regards,
    Himanshu Bhatnagar
    Andreas Kiel replied 15 years, 11 months ago 3 Members · 2 Replies
  • Cinnamon Kennedy
    September 4, 2010 at 5:28 pm
    Hi
    I’m just completing a subtitle-heavy project and for this I purchased a subtitling plugin called CVH Text – the basic fcp effects were ok but my people wanted more definition, which this plugin certainly gave. I also want to recommend two interfaces that I used a lot – “dotsub.com” – this allowed people to translate my stuff remotely and then I could download the .srt file into text edit, and “submerge”, a cheap little program that will blend an .srt file into an .mov file automatically.
    What I did was for putting the subtitles into fcp was, I created a subtitle in the definitions that I liked and then stretched/copied it all the way across, cutting it with each line of talking and then filling in the text by hand. I guess that’s sort of low tech but it worked.
    (By the way, the subtitling plugin that I recommended above had some issues with Apple ProRes 422. I had to switch over to DVCPRo.)
    Good luck!
  • Andreas Kiel
    September 6, 2010 at 3:47 pm
    SRT files do look like that:
    1
    00:00:12,000 --> 00:00:15,123
    This is the first subtitle
    2
    00:00:16,000 --> 00:00:18,000
    Another subtitle demonstrating tags:
    SUB files do look like that:
    10:00:02.560,10:00:06.400
    cercheremo di capire se lo squalo
    bianco è un mangiatore di uomini.
    10:00:08.080,10:00:10.240
    Di ritorno alle acque
    della zona degli squali,
    10:00:10.400,10:00:13.560
    i ragazzi hanno studiato un modo
    per vedere se lo squalo bianco
    If you got a finished movie, you should use a spotting app like SubBits or Belle Nuit, if you got your subtitles already in FCP you can use my TitleExchange to convert the subtitles to one of the formats.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
