Activity › Forums › Maxon Cinema 4D › How to create shadow + refection in single plane ?
  • How to create shadow + refection in single plane ?
    Posted by Alex Anderson on March 29, 2018 at 2:30 pm
    Hello All,
    i have this below render, where there is lava ball on tracked floor , now its easy to create shadow but how to create lava heat reflection [like glowing object on floor,which reflects glow] along with shadow or in this case with tracked floor ?
    check base of the lava ball , the floor should be glowing with heat emitted from lava ball
    Learn..Learn..Learn
    Steve Bentley replied 8 years, 6 months ago 3 Members · 3 Replies
  • Justin Thomson
    March 29, 2018 at 3:22 pm
    Will you compositing it?
  • Alex Anderson
    March 29, 2018 at 5:00 pm
    yes, im tracking a video and placing object in it. just wanted to know is it possible to cast the lava texture on floor along with shadow
    Learn..Learn..Learn
  • Steve Bentley
    March 29, 2018 at 8:12 pm
    You can put a texture on a light to “project” the image on a surface – the texture goes in the transparency channel.
    You can also render with GI and that will take the “light” from the texture and project that on the floor.
