Activity › Forums › Adobe After Effects › How to create real 3D stroke/beam in AE (What follows light path?)
  • How to create real 3D stroke/beam in AE (What follows light path?)
    Posted by Max Motionmoustache on August 15, 2016 at 5:32 pm
    So I basically have point A and point B that are in 3D space that I need to connect with a line/beam/stroke/cabel.
    I came up with particular following point light path but it has not best controls, as I need to rename manually ALOT to follow the light path that I need preoperly.
    Do you know if there is any pluging or effect that can simply follow the light path? or mby I can make a light beam to not effect object but just shine with color i need?
    Or can I create a 3D path for 3D stroke somehow?
    Thanks in advance, folks!
    Kalleheikki Kannisto replied 10 years, 1 month ago 2 Members · 1 Reply
