Activity › Forums › Apple Final Cut Pro Legacy › How to create mpeg 2 program stream
  • How to create mpeg 2 program stream
    Posted by Bill Wilnheim on July 14, 2011 at 12:08 pm
    I have a SD TV spot and one of the stations wants an mpeg 2 program stream. What is the best way to create this? I’m using FCP 4.5 and also have Compressor 1.2. Any ideas would be great, and if you think the answer is “Your system is too old!” then feel free to let me know as well :p
    If using my version of FCP isn’t an option, what is the best way to export it so I can do so in Premiere Pro CS 5.5, on a newer and faster PC?
    Andrew Evans replied 15 years, 2 months ago 3 Members · 2 Replies
  • Rafael Amador
    July 14, 2011 at 5:59 pm
    Hi Evan,
    yes, your software is too old.
    Use the search function (upper right), the process is very easy on FCS3. Not sure if PP can export those files, but I guess the Adobe Media Encoder can do it.
    rafael
    http://www.nagavideo.com
  • Andrew Evans
    July 14, 2011 at 11:17 pm
    I’ve never had much luck with program streams working from compressor. A TV station I’ve done some work for suggested adobe media encoder and it’s been what I’ve stuck with.
    Andrew Evans
    Lake TV
    iMac 2.5G Quad 8GB
    FCS 3
