Activity Forums Adobe After Effects How to create light streaks a long hundreds of paths?
  • How to create light streaks a long hundreds of paths?
    Posted by Ferenc Van der velde on August 12, 2015 at 1:25 pm
    Hi all,
    I would like to simulate a timelapse of traffic for one country. I have drawn all the main roads (hundreds of strokes) and now I would like to animate light streaks along these paths. At the moment I am using dashed lines and animating the offset. Then I use the echo effect to give it the looks of an energy beam.
    The problem with this method is that everything moves quite linear. To simulate a timelapse I would like to have a particle system in witch each particle picks a random path and has a different speed and life time. I am familiair with Particular, but I haven’t find a method to use it with random paths.
    Maybe there is another way to accomplish this?
    Thanks in advance!
    Ferenc Van der velde replied 11 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    August 13, 2015 at 9:12 am
    You could probably use this technique:
    https://www.youtube.com/watch?v=d1nGa-RGKpk
    In brief, create lights that travel along the paths and make Particular use those lights as emitters.
  • Ferenc Van der velde
    August 13, 2015 at 10:38 am
    Yeah I thought of that, but when you have hundreds of paths, the project becomes to slow to work with. I am now trying a simpler approach by using radial pulses (scaling circles with some turbulence displace ) and using all the roads as a track matte. It’s a lot better already, and not that slow anymore.
