Activity Forums Adobe Illustrator How to create embossed text with graphic wire mesh background
  • How to create embossed text with graphic wire mesh background
    Posted by Shah Jaihan on October 6, 2012 at 6:18 am
    Hi guys,
    I need help here. I tried all methods of embossing and bending to create the art work and end up failure.
    The text embossed from behind the texture (wire mesh) and there will no colour on the text or shadow and what so ever. The line of wire mesh will make it visible… the line will follow the text embossed shape and also creating shadow for the text… And also there a Logo pressed invloved.
    Please guys I need help ASAP… It’s been two week I tried to settle it.
    Regards,
    Shah
    Vincent Rosati replied 13 years, 11 months ago 2 Members · 1 Reply
  • Vincent Rosati
    October 8, 2012 at 11:57 pm
    Not sure if I’m exactly understanding what you need, but I might…
    Outline all of your objects.
    Duplicate the mesh and put it on top of the text, than use the top mesh as a mask on the text.
    I’d guess you’d have to offset, or even duplicate this object for multiple offsets, than nudge the object appropriately.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
