Activity › Forums › Adobe Encore DVD › How to create disc image for remote burning, from 1.5 ?
  • How to create disc image for remote burning, from 1.5 ?
    Posted by Mike Smith on October 24, 2007 at 10:17 am
    Is there a way in Encore 1.5 (or later) to create a set of files (ISO disc image?) I can hand off / make available to a client (not very technical) so that he can use (what software?) these to burn working DVDs at his end?
    I tried the disc image setting – produced an .img file, which may be good for burning from Encore but is not recognised by InstantCD. Creating a set of folders and burning those to disc did not produce a playable DVD.
    Other than using a 3rd party tool to rip a DVD, any thoughts on possible ways forward?
    Nick Williams replied 16 years, 11 months ago 4 Members · 4 Replies
  • Jeff Bellune
    October 24, 2007 at 11:14 am
    1. Rename your .img files to .iso – that should allow InstantCD to work. If not:
    2. The excellent ImgBurn – it’s free.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Mike Smith
    October 24, 2007 at 1:42 pm
    Thanks Jeff – that’s fixed my problem.
    I tried renaming the Encore-made image file to .iso, but somehow ended up with discs that play fine on computer but not in standalone players. Couldn’t see what setting I was missing in InstantCD (if any) – so tried imgburn.
    And, I’m delighted to report, that looks like it’s done the job!
    Again. many thanks for the help.
    Mike
  • Scot Sheely
    October 31, 2007 at 6:57 am
    Mike,
    We have always created a final version of the DVD, then used Roxio Easy CD Creator to create the .ISO image by going to the DISC menu, choosing the drive letter on the left-hand side of the pop-up window and clicking on the READ TRACK button at the bottom.
    This opens up another submenu, which allows you to name the image file and select the archive’s directory (the loaction where you want to save the .ISO image to).
    Once created, any standard burning ROM will easily burn the .ISO image, such as Nero, Prassi or RecordNow, amongst others.
    Of course, in version 2.0 and CS3 of Encore, the “Create Disc Image” feature is built in, eliminating the need for a third-party app.
    Scot
  • Nick Williams
    October 31, 2009 at 1:27 pm
    Worked perfectly! Many thanks to you and ImgBurn for such helpful advice and saving my sanity when I thought that 4 months work was trapped in a defunct file format! Nick
