Activity › Forums › Maxon Cinema 4D › How to create a unfold / peel off animation.
Posted by Din Iulian silviu on October 10, 2020 at 7:19 pmHello.
I have to create an animation similar with the attached image.
How to create in cinema 4D this effect?
Thanks in advance!
Din Iulian silviu replied 5 years, 11 months ago 3 Members · 6 Replies -
Jim Scott
October 10, 2020 at 9:29 pmTo create a peeling effect look into using the bend deformer. Here’s a tutorial that should help.
https://www.youtube.com/watch?v=zOKXEuwU5d4
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Din Iulian silviu
October 12, 2020 at 6:12 amthank you, but it doesn’t help me;
I want that the unfolding effect to be at 45 degrees, as if you were pulling left and up simultaneously, please see me reference image.
Kind Regards!
Jim Scott
October 12, 2020 at 2:32 pmRotate the deformer so that it isn’t in alignment with the paper.
Jim Scott
October 12, 2020 at 4:20 pmFor more help, please upload your project file. Use the “attach document” button at the bottom of the reply window.
Michael Szalapski
October 12, 2020 at 8:53 pmLots of tutorials for it online. Find one that you like the look of the best.
