How to create a transition from shapes. (or anything else that works)
Hello again 🙂
I’m editing a new video, and this time I’m trying to achieve an alternative “transition” on my video. I want my screen being splited from center to the corners and then reveal a second video below it. I’ll post some images to make the best picturize it.
First, I’m trying to get two shapes coming each from one side of the video. The two shapes do not overwrite each other, but they get really close so when both reach the other edges they become one.
Second, I want to split them and reveal a second video below it.
At some point it should look something like this:
I watched this slider tutorial (https://youtu.be/OMBR_iFuLws), but I couldn’t animate it. I achieved 2 different keyframes but there is no transition between them. I go to the first, get the slider to 0, go to the second and raise it to 100, whe I go back to the first keyframe, it is also at 100. 🙁
I’m editing the video on Premiere, so it should be something I could get from Ae to Pr. This “transition” should be implemented here:
My english is not the best, so I hope the pictures can help you get a better idea of what I’m trying to do. And yes, I’m completly lost.
Thank you all.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
