Activity Forums Zaxwerks How to create a ring, that is cylinderical all the way around?
  • How to create a ring, that is cylinderical all the way around?
    Posted by Chrisco on May 6, 2006 at 4:06 am
    Hey guys
    I need to make a ring shaped object, that is like a a circluar pipe, rather than some of the half pipe options.
    Everything i have come accross makes it curved onthe outside of the ring and the inside is iether hollow (not the Front and Back Faces) or soemthign different.
    I have Invig 4pro.
    Chrisco
    Serge Hamad replied 20 years, 4 months ago 2 Members · 1 Reply
  • Serge Hamad
    May 6, 2006 at 4:43 am
    If I got you right, you are looking for a “Torus”. As you have Invigorator 4.0 (Make sure you upgrad for free to 4.0.7) You could create one right away by selecting: Object>Create 3D Primitive. Invigorator will first create a sphere but you could then once you select the sphere turn it to a torus in the Object menu.
    Does this help?
    Salut.
    Serge
    “InvigoMany” is available here:
    https://www.nyc-visual.com
