Activity › Forums › Adobe After Effects › How to create a full moon?
  • Bill Clotz
    January 10, 2006 at 8:17 pm
    The best way would probably be to just use an image of one. There are a number of high quality photos of the moon on Google Image Search, just be careful about violating copyrights.
    Or maybe this isn’t exactly what you meant?
  • Charlie Chang
    January 10, 2006 at 8:26 pm
    Thank you for the response. Yes, I was thinking about that too, but the problem is, how do I animate the moon so it looks like the moon shines onto the forground?
  • Justin Productions
    January 10, 2006 at 10:55 pm
    Trapcode > Shine on http://www.trapcode.com.
    By the way, if you’re starting in After Effects, I suggest you really learn the basics.
    Hope that helped.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Graham Quince
    January 11, 2006 at 8:45 am
    Avoiding spending on a plugin. You can create a ground reflection of the moon quite easily. I’m going to suggest the most basic way of doing this as there are several options but I don’t want to confuse you.
    Bring in a copy of the moon you choose and press ‘S’ to reveal the scale options. There’s a small link symbol next to the two percentages. Uncheck this. Now, grab the top of the moon layer and pull it below the bottom of itself. The moon should turn upside down. You can now pull the sides and top and bottom to get it looking just right for a reflection.
    Once you’re happy, adjust the transfer mode to something like ‘screen’ until it looks more like a reflection. And you’re done.
    Hope that helps
    Graham
    http://www.qcit.com
  • Charlie Chang
    January 11, 2006 at 4:38 pm
    Thanks! I’ll try that tonight.
