Activity Forums Adobe After Effects how to create a freeze
  • how to create a freeze
    Posted by Gunnar Kordestani on June 3, 2007 at 6:49 am
    hi everybody,
    should be a simple issue, but cant find it.
    1.) How can I create a freeze out of video footage.
    2.) How to make shure that the freeze is not flickering between the lines (as i dont have a video monitor here i wouldn’t see if it does)?
    thx
    Gunnar
    Gunnar Kordestani replied 19 years, 3 months ago 2 Members · 2 Replies
  • Mike Clasby
    June 3, 2007 at 11:39 pm
    A couple of ways.
    1) Composition>Save Frame As, will give you a still .psd of where you are on the timeline.
    2) Select the layer then Layer>Enable Time Remapping. Go to where you want the still, then click the “Add or Remove Keyframe at Current Time” box (below the eyeball), to get that little checkmark. Then go delete that last Time Remap keyframe.
  • Gunnar Kordestani
    June 4, 2007 at 12:55 am
    hi there,
    the ‘timeremap’ way i just found out myself. Thx anyway.
    gunnar
