Activity Forums Apple Final Cut Pro Legacy How to create a duplicate project file in FCP 6 and convert to FCP 7
  • How to create a duplicate project file in FCP 6 and convert to FCP 7
    Posted by Tamera Coleman on September 9, 2014 at 4:30 am
    Hello, I am trying to convert a FCP 6 project > FCP 7. I was given seemingly easy instructions (1) create a FCP 7 folder on the external HD (2) duplicate the project file (3) copy it to the FCP 7 folder (4) open FCP 7 application then open the duplicate version of the project file that was saved to the new FCP 7 folder.
    My question: Is there a ‘visual/tutorial’ available, so I can identify the project file? What should the project file look like?
    Also, I read a post that suggested using media manager and copying everything over {rendered files, etc]. Thanks.
    Daniel Sametz replied 11 years, 11 months ago 2 Members · 3 Replies
  • Daniel Sametz
    September 9, 2014 at 5:44 am
    It will look like this.
    Move you old project, render files, capture scratch, auto save files, etc to a external HDD (Because you should always edit in an external HDD), then duplicate your old project file (like the one on the picture) so you´ll leave your original safe and open it on Final 7.It will ask you if you want to convert it to final 7 or something like that, say yes and there you are.
    Good luck 🙂
  • Tamera Coleman
    September 9, 2014 at 4:07 pm
    Thanks. But want to clarify. You’re suggesting I “move” the project file. Shouldn’t the file(s) be copied to the external HD, not “moved”?
  • Daniel Sametz
    September 23, 2014 at 9:37 pm
    Sorry for the delay.
    So If move your project file it does´t matter as long as what you open is your duplicate and not the original. Keep a copy of what you are moving in it´s original place but make sure you change the project settings to your new place.
