Activity Forums Adobe Photoshop How to create a dotted line?
  • How to create a dotted line?
    Posted by Mr.inker on March 1, 2007 at 9:39 pm
    I need to create a “dotted line” around an ad we made for newspaper print. I need this dotted line to outline the ad to create a “cut-out” coupon look. Like, you would cut along the dotted line. The ad is already done, so if you could answer on how to create it as well as how to add it to the already done ad, I would be most gratefull.
    Inker
    Scotia2k7 replied 19 years, 6 months ago 2 Members · 1 Reply
  • Scotia2k7
    March 2, 2007 at 2:59 pm
    Hi there – There’s probably a “proper” way to do this, but here’s mine!
    Id use the type tool, with a font that produces the kind of “dot” I want, then duplicate this, (right click the type layer and selecet duplicate) then go through “edit/transform/rotate 90CW” – position the verticle layer where you need it to be, then in the layers palette, merge this layer down to the layer below (it will ask you if you want to rasterize, yip) Then duplicate this new merged layer, and edit/transform/horizontal.
    Hope that helps!
    Scotia 😉
