Activity › Forums › Adobe After Effects Expressions › How to create a button to change text with prompt toolkit
Posted by Adrián Wulfrath on March 30, 2016 at 6:04 pmHow can i create a button and text fields to change source text in after effects. With Script. In Extend Toolkit.
Adrián Wulfrath replied 10 years, 5 months ago 3 Members · 20 Replies -
Kevin Camp
March 31, 2016 at 4:52 pmthis tutorial covers many aspects of creating a GUI panel for after effects with extend script:
https://www.provideocoalition.com/after-effects-extendscript-training-ep-11/
it’s for a floating panel, but I believe they also have one for a dockable panel.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW -
Adrián Wulfrath
March 31, 2016 at 7:44 pmReally Cool, actually i made a Dropdown menu in my Script, but how can i connect that dropdown menu to another dropdownmenu inside AfterEffects of another controller. Here is my Screen Shot and actually i want to link the dropdown menu from myWindow to the DropdownMenu from the Effect Panel inside after effects.
The first layer never going to move. So i think the Array always can be [1] for that layer that have the Dropdown Menu inside the Effects Panel.
Dan Ebberts
March 31, 2016 at 8:00 pmIf I understand what you’re doing, I think you need to create an onChange function to update the project whenever the dropdown is changed. It will look something like:
yourDropdownObject.onChange = updateProject;
function updateProject(){
(update project to match new state of dropdown)
}The JavaScript Tools guide should help.
Dan
Adrián Wulfrath
March 31, 2016 at 8:04 pmSomething like this will change the dropdown menu inside my Effect panel according to the dropdown menu in MyWindow?????:
//Creating My Window
var myWin = new Window (“palette”,”Canal 5 Controles”,undefined);
myWin.orientation = “row”;var groupOne = myWin.add(“panel”,undefined,”MasterControles”);
groupOne.orientation = “column”;
groupOne.add (“image”,undefined,”~/Desktop/LogoC5Ctrl.png”)
groupOne.add(“statictext”,undefined,”Primer Grupo”)
var dd = groupOne.add(“dropdownlist”,undefined,[“OFF”,”Amarillo”]);
dd.selection = 0;
groupOne.add(“checkbox”,undefined,”Caritas”);//Action of my DropDownMenu
dd.onChange = updateProject;function updateProject(){
}myWin.center();
myWin.show(); -
Dan Ebberts
March 31, 2016 at 8:12 pmYeah, like that. Inside the function, you need to have code that navigates to the comp/layer/effect/property that needs to be updated and sets the appropriate value.
Dan
Adrián Wulfrath
March 31, 2016 at 8:25 pmI made this to prove the Dropdown menu and it works with the Tint Effect but, always change the value to 0, but how can i work with the PseudoEffect???? and detect the dropdown menu list???
dd.selection = 0;
var lis = dd.selection = 0;
lis = app.project.item(1).layer(1).property(“Effects”).property(“Tint”).property(“Amount to Tint”).setValue([100]);
var lis1 = dd.selection = 1;
lis1 = app.project.item(1).layer(1).property(“Effects”).property(“Tint”).property(“Amount to Tint”).setValue([0]);myWin.center();
myWin.show(); -
Dan Ebberts
March 31, 2016 at 9:10 pmYou should get Jeff Almasol’s rd_GimmePropPath.jsx script, which will give you the scripting path to any properties in your comp. You can get it here:
https://www.redefinery.com/ae/rd_scripts/
Dan
Adrián Wulfrath
March 31, 2016 at 10:23 pmThank you a lot, i will try with that script. Probably i will have another question. So actually i do not close this post.
Adrián Wulfrath
March 31, 2016 at 10:55 pmOk i got it, but now how can i assign for each dropdown menu list a different Root Object:
dd.selection = 0;
var lis = dd.selection = 1
lis = app.project.item(1).layer(“Control”).property(“Effects”).property(“Control”).property(“Color System”).setValue([4]);
}myWin.center();
myWin.show(); -
Dan Ebberts
March 31, 2016 at 11:55 pmOne way would be to have a different onChange function for each dropdown.
Or you could add code to the function to figure out which dropdown has been modified.
Dan
