Activity › Forums › Adobe After Effects Expressions › How to create a button to change text with prompt toolkit
Adrián Wulfrath replied 10 years, 5 months ago 3 Members · 20 Replies
Dan Ebberts
April 1, 2016 at 12:40 amAssuming you have given all your dropdowns unique names (like dd.name = “dd1”), I guess it would look like this:
function updateProject(){
switch (this.name){
case "dd1":
// do stuff for dropdown named "dd1"
break;
case "dd2":
// do stuff for dropdown named "dd2"
break;
default:
break;
I haven’t tested any of this (I build my panels a different way), but it’s my best guess.
Dan
Adrián Wulfrath
April 1, 2016 at 1:14 amSomething like this??????:
//Creating My Window
var myWin = new Window (“palette”,”Canal 5 Controles”,undefined,{resizeable: false , maximizeButton: false});
myWin.orientation = “row”;var groupOne = myWin.add(“panel”,undefined,”MasterControles”);
groupOne.orientation = “column”;
groupOne.add (“iconbutton”,undefined,”~/Desktop/LogoC5Ctrl.png”,”https://www.google.com”)
groupOne.add(“statictext”,undefined,”Primer Grupo”)
var dd = groupOne.add(“dropdownlist”,undefined,[“OFF”,”Amarillo”,”Rojo”]);
dd.selection = 0;
groupOne.add(“checkbox”,undefined,”Caritas”);
groupOne.add(“checkbox”,undefined,”Iconos”);//Action of my DropDownMenu
dd.onChange = updateProject;function updateProject(){
switch (this.name){
case “dd1”:
// do stuff for dropdown named “dd1”
selection = 1
app.project.item(7).layer(“_Control”).property(“Effects”).property(“Control v2”).property(“Color System”).setValue([1]);
break;
case “dd2”:
// do stuff for dropdown named “dd2”
selection = 2
app.project.item(7).layer(“_Control”).property(“Effects”).property(“Control v2”).property(“Color System”).setValue([3]);
break;
default:
break;
}myWin.center();
myWin.show(); -
Adrián Wulfrath
April 1, 2016 at 1:20 amI actually prove it but doesnt work, i dont know if i need something more or less. But how did you do your dropdown list ???
Dan Ebberts
April 1, 2016 at 1:43 am>But how did you do your dropdown list ???
I almost always use a resource string to build the entire palette/window.
Adrián Wulfrath
April 1, 2016 at 1:48 amMy Dropdown list is a Pseudo Effect inside a _Control Layer: Somethig like this:
Layer: _Control
Effect: Control v2
Dropdownlist -> OFF
Amarillo
Rojo
MoradoAnd i want to connect from my Script depending of Selection to the Dropdown list of my Effect. Thats because im calling the app.project.item bla bla bla
All i want to connect is that dropdown menu to my dropdownlist in my script window. -
Adrián Wulfrath
April 1, 2016 at 5:48 pmMy Dropdown list is a Pseudo Effect inside a _Control Layer: Somethig like this:
Layer: _Control
Effect: Control v2
Dropdownlist
-OFF
-Amarillo
-Rojo
-MoradoAnd i want to connect from my Script depending of Selection to the Dropdown list of my Effect. Thats because im calling the app.project.item bla bla bla
Adrián Wulfrath
April 4, 2016 at 6:29 pmHey Dan, thank you for all, i actually got it with this code:
But do you know how to link the checkbox with an effect checkbox????//Creating My Window
dd.selection = 0;
groupOne.add(“checkbox”,undefined,”Iconos”);dd.onChange = updateProject;
var dropSelection = dd.selection.text;switch (dropSelection){
case “OFF”:
alert(“blabla”);
break;
case “Amarillo”:
alert(“jaja”);
break;
case “Rojo”:
alert(“Rojo”);
break;default:
alert(“default”);
break;
}myWin.center();
myWin.show(); -
Dan Ebberts
April 4, 2016 at 7:21 pmIt’s very similar, except you would use onClick instead of onChange.
var CB1 = groupOne.add(“checkbox”,undefined,”Caritas”);
CB1.onClick = clickCB1;
function clickCB1(){
//set effect checkbox to same value as CB1
}Dan
