Activity Forums Apple Final Cut Pro how to copy an event from Macintosh HD to a scratch disk?
  • how to copy an event from Macintosh HD to a scratch disk?
    Posted by Ken Eakins on June 27, 2013 at 8:32 pm
    Hi, so this is a bit of a weird question, so bear with me on this one.
    I’m syncing footage from three cameras in Plural Eyes 3, and then exporting out to Final Cut X.
    However, when I export from Plural Eyes, it sends everything to my Macintosh HD.
    My question, how do I now copy that synced event to my scratch disk?
    Thanks in advance, you guys are always life savers.
    **edit**
    Just thought I should add, I synced the clips originally using the Plural Eyes software directly, rather than via FCP. Perhaps I should export from FCP X – PE?
    Nikolas Bäurle replied 13 years, 2 months ago 2 Members · 1 Reply
  • Nikolas Bäurle
    June 28, 2013 at 9:49 am
    When you open FCP you should see the connected scratch disk. Then you pull the event icon from your internal drive to the scratch disk icon. FCP will ask you for a new name, when its done duplicating you can delete the old event.
    “Always look on the bright side of life” – Monty Python
