Activity › Forums › Adobe Premiere Pro › How to convert interlaced to progressive avi
Posted by Vasco Daneva on October 27, 2013 at 4:37 pmI want to use Red Giant’s instant HD on some very old footage. But the Instant HD only works with progressive and my footage is interlaced. Red Giant say you have to convert it to progressive first. How do I do that?
Vasco Daneva replied 12 years, 11 months ago 4 Members · 5 Replies -
Ann Bens
October 27, 2013 at 5:48 pmNever encountered that message.
Used it on mini dv footage.
Where does it say you have to convert?———————————————–
Adobe Certified Expert Premiere Pro CC
Adobe Community Professional -
Vasco Daneva
October 27, 2013 at 6:32 pmInstant HD User Guide. Page 5 under Instant HD Controls. Quote:
There is one major limitation in the current Instant HD release. The product is specifically designed to work with progressive (non-interlaced) images. That means that if you are starting with interlaced video such as a standard Sony PD150 DVCAM capture, you will need to convert the image to progressive in the host application before applying Instant HD.
Tim Kolb
October 28, 2013 at 12:39 amLike Ann, I’ve used Instant HD on interlaced footage many times over the years…never looked at the manual.
I’m not sure what will constitute de-interlacing before the plugin gets it…I suspect if you interpolate the video on the timeline with field options, it may not work properly.
I would say to interpolate the footage from the project panel (right-click > modify)
TimK,
Director, Consultant
Kolb Productions,Adobe Certified Instructor
Marcin Grabos
October 28, 2013 at 1:24 amVery good deinterlacer you will find inside free Virtualdub [Yadif interpolation, under video->filters->deinterlace(internal)]. Save file as uncompressed (default). I would recommend to try as well resize filter in Virtualdub (has many different algorithms to choose from), so later you can compare result with work of Red Giant filter.
In what format is this old footage? -
Vasco Daneva
October 28, 2013 at 9:06 amIt was originally a VHS tape (PAL) shot in 1984. I recently converted it to uncompressed avi.
