Activity Forums DaVinci Resolve How to convert HD-1080-rec709 to 2k-DCI
  • How to convert HD-1080-rec709 to 2k-DCI
    Posted by Knut Jansohn on January 22, 2012 at 7:09 pm
    Hello,
    I am usually working for broadcast deliver.
    But now, after finishing a short a client asked me to build a DCI-p3 Version.
    I’ve done some research and find a 709toXYZ-lut in this forum. Thanks a lot to Oyvind Stiauren!.
    Now after applying this lut I’ve rendered colorbars to 16 bit dpx.
    The code values on the resolve waveform stayed 0-1023 as before. On my ultrascope I see now something slightly under 940 (around 97%) for white and blacks still remain. Monitoring is legal scaled.
    And that’s it what lets my be confused. I expected code values from 96-685 (these are the presets in baselight format-editor for 2k)
    So do I miss something?
    How are the correct values for black and white in dci-p3?
    Any help appreciated.
    Thanks & regards
    Knut
    Ola Haldor voll replied 14 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Ola Haldor voll
    January 23, 2012 at 10:04 am
    I always render unscaled for DCI P3 / XYZ deliveries. Haven’t had any negative feedback on that.
  • Knut Jansohn
    January 23, 2012 at 10:27 am
    Thanks Ola.
    Do you use the rgbXYZ-lut delivered with resolve? Without any further correction?
    What do you think about the lut from Oyvind?
    This lut gives a little gamma-lift compared to the resolve-lut, which may compensate the lower brightness of the projection.
  • Ola Haldor voll
    January 23, 2012 at 8:29 pm
    Haven’t seen that LUT you mention. I use the one that came with Resolve. I’m also grading most of the things going to cinema on a Christie projector, so I know it looks exactly the same when it’s being viewed with an audience.
  • Knut Jansohn
    January 23, 2012 at 9:12 pm
    Ok, grading on a Christie for cinema is certainly a good way but unfortunately not an option for me now.
    Anyone else with good experience using either the rgb2xyz-lut from resolve or the lut from this thread:
    https://forums.creativecow.net/thread/277/5053
    Is there any thing else to do, or could I expect to see ‘more or less’ the picture I graded in 709?
    Thanks.
  • Fred Ricci
    January 24, 2012 at 9:50 am
    Hi Knut
    I use the Rec709 to XYZ found in this forum and it works fine for me. Going from 5D, 7D, XdCam EX and F3 to XYZ after grading and it looks good.
    NEHALEM OCTO 2,26
    GT 120
    GTX 285
    8 Giga RAM
    SOFT RAID 8 Tera
    Wave
    Eizo 243 + Hdlink displayport
    DAV, COLOR, FINAL CUT AND MEDIA COMP
  • Knut Jansohn
    January 24, 2012 at 10:10 am
    Hi Fred,
    thanks. I will go with it too.
  • Ola Haldor voll
    January 24, 2012 at 12:00 pm
    Yeah it’s a deal I’m very thankful to have. It also helps to have a great monitor to start with. I got the Autocue BM-AC24T before Christmas, and I’m very impressed. I can get very close to what it will look like in the cinema with it.
    The times I’m on the Christie is for that final touch right before rendering.
