Activity Forums VEGAS Pro How to Convert anInterlaced Clip to progressive
  • How to Convert anInterlaced Clip to progressive
    Posted by Mark Thompson on September 24, 2013 at 2:34 pm
    I’m trying to convert some HDV Interlaced Clips to progressive. I thought this was easy; just “Render As” to a progressive format. However looking at the output, it still has the interlaced artefacts (comb on movement). Vegas thinks it is progressive, I’m sure it is. However it (Mainconcept) seems not to have done a very good job at it.
    Are there better settings or codecs?
    thanks in advance.
    John Rofrano replied 13 years ago 2 Members · 5 Replies
  • John Rofrano
    September 24, 2013 at 3:16 pm
    [mark thompson] “Vegas thinks it is progressive, I’m sure it is. However it (Mainconcept) seems not to have done a very good job at it.”
    What are your project properties set to? Particularly, what Deinterlace Method did you choose?
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mark Thompson
    September 24, 2013 at 5:24 pm
    John,
    thanks for that – it was none.
    I should have spotted that, I’m trying the options now.
  • John Rofrano
    September 24, 2013 at 5:38 pm
    [mark thompson] “thanks for that – it was none.”
    Yup… You told it not to deinterlace and it didn’t! 😉
    ~jr
  • Mark Thompson
    September 24, 2013 at 5:53 pm
    it looks much nicer now
  • John Rofrano
    September 25, 2013 at 11:26 am
    [mark thompson] “it looks much nicer now”
    Glad to hear that. Always remember; if you have interlaced footage anywhere in your project you MUST set the deinterlaced method so something other than “none” or else you will have problems.
    ~jr
