Activity Forums Compression Techniques How to control the size of Intra Frame
  • How to control the size of Intra Frame
    Posted by Uma Kant on December 1, 2011 at 8:58 am
    Hi All,
    Is there way to control the size of I-Frame generated by ffmpeg h263 encoder? I am encoding jpeg file using h263 encoder and sending it over network. what i found that I-Frame size of stream is very big. Now i want to reduce it.Please share if there are properties of H263 codec that will help me to reduce the size of Initial I-Frame.
    Thanks in Advance
    Uma Kant replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
