Activity › Forums › Adobe After Effects › How to connect/merge two layers
  • How to connect/merge two layers
    Posted by Jaroslaw Kaminski on October 2, 2018 at 12:57 pm
    I have had one layer, which I accidentally splitted into 2, using command ctrl+shift+d (the layer was selected as well, I didn’t see that). I went further into animation and when I saw my error, I wanted to join these two layers together, but couldn’t find an option. How to do that, but just simply connect them together, like I would hit Ctrl+z
    Eric Santiago replied 7 years, 11 months ago 3 Members · 2 Replies
  • Ken Teutsch
    October 2, 2018 at 1:07 pm
    The original layer is still all there. Just drag out the end. Then you can delete the “split” version.
  • Eric Santiago
    October 2, 2018 at 3:22 pm
    And if you did any extra attributes to the second layer e.g. keyframes, effects, etc… just copy and paste them to the final layer.
