Activity › Forums › Maxon Cinema 4D › How to connect objects to an animated mesh?
  • Hans Nordelius
    August 11, 2021 at 8:55 am
  • Justin Thomson
    August 11, 2021 at 3:09 pm
    I can’t download the videos, but have you tried parenting the object to the mesh?
  • Hans Nordelius
    August 11, 2021 at 5:42 pm
    Yes but it only works on static mesh.
  • Justin Thomson
    August 11, 2021 at 9:55 pm
    Any chance you can share the videos in different way? Getting an error when tryin to download.
  • Andy Kiernan
    August 24, 2021 at 3:49 pm
    you can use xpresso, specifically, the point node, feed the geo into it, change the point index to a useful point, make sure, use deformed points is on, then feed the point pos out to the position of the ‘wig’ geo.
    if you ever need to attach a cloner, you can use the edge to spline plug in and clone on to the generated spline.
