Activity › Forums › Blackmagic Design › How to connect component input cable and S-Video out cable?
  • How to connect component input cable and S-Video out cable?
    Posted by Paul Strilka on July 18, 2007 at 2:17 pm
    I have the BM HD Extreme. The codecs are not showing up in my sequence settings- which is annoying- but I think I found a workaround.
    My new problem is: How do you connect a S video cable?
    I am using the BNC Component Connections as my source input (IN) and and
    monitor feed (OUT). I want to be able to also output to a DVD recorder.
    I realize I can send the BM card output to the DVD recorder and monitor output from the recorder- but I don’t need or want to do that. I like to monitor a direct feed while I edit.
    (The DVD recorder is monitored on a different monitor)
    I also have no idea what kind of cable I need to do this. The BM card only has BNC connects.
    Can someone please explain and maybe link me to an image of type of cable I need.
    Thanks much.
    Joshua Helling replied 19 years, 2 months ago 3 Members · 2 Replies
