Activity Forums Storage & Archiving How to Configure Xen to run off backup iSCSI storage?
  • How to Configure Xen to run off backup iSCSI storage?
    Posted by Irrani Dam on December 1, 2009 at 2:03 am
    I have a iSCSI storage controller, with built in replication
    for DR. I have on SAN at our primary location (Production), and
    another SAN in a DR Location (Disater Recovery). Everything is working
    great with our primary SAN, however I would like to connect our VM
    servers at our Primary location to connect to our DR SAN location and
    be able to start backup VM servers from the DR SAN.
    kind regarads,
    Irrani
    Edwards Willeam replied 16 years, 9 months ago 3 Members · 2 Replies
  • Bob Herzan
    December 2, 2009 at 1:37 pm
    We would need more information to be able to help you out on this. If you contact us we certainly can try to walk you through your options.
    You can contact me directly at bherzan@rorke.com and will try to give you a hand.
    Bob Herzan
    Vice President of Sales
    Rorke Data Inc
    952-829-0300
  • Edwards Willeam
    December 3, 2009 at 1:00 am
    This could in theory work, however you’ll most likely need to perform
    a few manual steps in configuring the storage repository. At a bare
    minimum, you’ll need to ensure that:
    1. Both XenServers operate on the same subnet or are at least routable
    to eachother.
    2. The XenServers need to be placed in a pool and must have
    communication with eachother.
    3. Ideally the LUNs presented by the iSCSI storage have the same IDs –
    if not, you’ll need to manually create the PBDs (see
    https://docs.xensource.com/XenServer/5.0.0/1.0/en_gb/reference.html#cl…)
    to reflect the DR SAN’s LUN configuration.
    If this is all too much, there is an alternative which may be of
    interest. This method does not require the XenServer hosts to be in a
    pool, but you’ll need to be sure not to start up VMs up from the DR
    SAN – you will need to investigate what would happen if your DR SAN
    had writes to it from the DR XenServer host. This solution would work
    as follows:
    1. Configure two discrete XenServer hosts (not in a pool) – one for
    primary usage, the other for DR.
    2. Through the XSConsole (run xsconsole if you wish to use this from
    the XenCenter console or SSH), select “Backup, Restore and Update” and
    then schedule regular metadata backups.
    To restore, you would simply create a new SR on your DR XenServer host
    and perform a metadata restore (same procedure as step 2 above, just
    choose “restore”).
    Thanks..
    Edwards
