Activity Forums Apple Final Cut Pro Legacy How to configure LaCie Biggest S2S for use in FCP
  • How to configure LaCie Biggest S2S for use in FCP
    Posted by Broelando on October 3, 2007 at 4:41 pm
    I’m about to purchase a LaCie Biggest S2S drive to do a multicam (7 cams) DV50 project on a Mac Pro using FCP 6. What is the best way to configure it? Use RAID 5, RAID 0? (LaCie has a confusing naming policy like JBOD, Fast, Safe+Fast). If possible I wanna use the RAID 5 option because that gives added safety (if one drive crashes you dont loose data) and you loose the least amount of drive capacity. You recommend RAID 5 too? Or do I best use another type of RAID?
    Miodrag Ristic replied 18 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    October 3, 2007 at 4:54 pm
    I don’t think that drive supports RAID 5. And if it did, it would probably drop the speed too much.
    We run ours in RAID 0 with a Firewire backup drive.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Broelando
    October 3, 2007 at 5:06 pm
    Mmhh your right, it only has RAID 0+1 (that is the Safe+Fast option probably) but you will loose 50% of your drive size… Backup to FW drives is probably the cheapest option, do you have any backup utilities you use for that or do you just manually copy everything?
    BTW: Are there any other drives you recommend beside the LaCie Biggest S2S?
  • David Roth weiss
    October 3, 2007 at 5:09 pm
    As Walter said, Raid 5 is not an option. That’s because Raid-5 is not software, its built-in to hardware controllers both as cards in CPU towers and cards in raid enclosures. Raids 1&0 available to you on LaCie drives are software raids. Raid-1, or mirroring provides backup, but at the expense of half the drive space and half the speed. Raid-5 protection only comes at a price, typically three times the price of hardware that only does Raid-0.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Walter Biscardi
    October 3, 2007 at 5:42 pm
    [Broelando] “Backup to FW drives is probably the cheapest option, do you have any backup utilities you use for that or do you just manually copy everything?”
    We use a LaCie 2TB FW800 drive. I just do it manually.
    [Broelando] “BTW: Are there any other drives you recommend beside the LaCie Biggest S2S?”
    Yeah, MaxxDigital. We run two of their 8TB SAS/SATA arrays here. Website of the same name. We get almost 500MB/s in RAID 5 running off an ATTO R380 Controller.
  • Miodrag Ristic
    October 4, 2007 at 4:37 am
    David,
    Does it mean that he needs something like tis card that is now offered by
    Apple as a configuration option on their website.
    Secondly, can I use this card on my G5 with PCI express slot,
    (it si however called Mac Pro RAID card):
    The Mac Pro RAID card offers improved performance and data protection to your Mac Pro system
  • Walter Biscardi
    October 4, 2007 at 12:11 pm
    [Miodrag Ristic] “Does it mean that he needs something like tis card that is now offered by
    Apple as a configuration option on their website.”
    I believe that is only for internal RAID setups as noted below.
    .[Miodrag Ristic] “To enable your Mac Pro for hardware RAID, select the Mac Pro RAID card option and two or more hard drives in bays 1 through 4. Each RAID level has minimum requirements for the number of hard drives:”
    They are talking about the internal Mac Pro Drive Bays 1-4. That is not for external arrays. For the LaCie you run the card that comes with the product.
  • Miodrag Ristic
    October 6, 2007 at 9:55 am
    Thanks Walter, I get it now.
    Mio
