Activity › Forums › Maxon Cinema 4D › How to clone splines and have them morph over the count
  • How to clone splines and have them morph over the count
    Posted by Andre Ash on January 23, 2019 at 1:47 pm
    I’m looking to clone splines and have them morph over the count.
    So the first spline in the clone count is a square and the last clone is a circle.
    Like what the loft nurb does but without creating the polygons that join them.
    Any ideas
    See screenshot and imagine the last shape is a square.
    Here is another screenshot of a square becoming a circle using a loft nurb, but as you can see it create all the rest of the geometry. Also you I can’t align a loft nurb to bend along a curve.
    Please help.
    Brian Jones replied 7 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    January 23, 2019 at 10:25 pm
    in the cloner that’s what the Clones setting is for in the object tab of the cloner. It defaults to Iterate but you want Blend (check the help for better info) – it needs editable splines and it seems to work best with similar numbers of points in the splines and if Intermediate Points is set to none (with a lot of points for smoothness)
