Activity › Forums › Adobe After Effects › How to check if a property value is readonly using extendscript?
  • How to check if a property value is readonly using extendscript?
    Posted by Miguel De mendoza on August 2, 2015 at 12:26 pm
    I’m writing a script that collects all properties from a layer and write them into an XML file. When I retrieve the values from the XML,
    some values are readOnly and the toolkit throws an error.
    Is there any way to check it, like readonly attribute on File object?
    ie: layer.property().(readonly||readOnly)
    If not, someone can tell me wich aproach can I take to go in the right direction?
    Miguel De mendoza replied 11 years, 1 month ago 2 Members · 2 Replies
