Activity › Forums › Adobe After Effects Expressions › How to check by name if a slider exist on a layer ?
Posted by Tal Arbiv on December 25, 2016 at 10:18 pmI know how to check for layer by name but property?
and also, how can i check the number of dimensions on an effect property?Thanks
if (myComp.layer("Layer Name").Effect("ADBE Slider Control").property("Slider") == null){
var exists =false;
}else{
var exists =true;
}Tal Arbiv replied 9 years, 8 months ago 2 Members · 8 Replies -
Dan Ebberts
December 26, 2016 at 7:49 amExpression or script? Something like this should work for an expression:
try{
thisComp.layer("Layer Name").effect("Slider Control")("Slider");
exists = true;
}catch(err){
exists = false;
It would be similar for a script.
Dan
Tal Arbiv
December 26, 2016 at 6:41 pmThank you so much Dan!
yes its scripting…
The second question i had was how can i tell how many dimensions a property has ?
i’m applying an expression to layers and i want the expression to change according to the dimensions…lets take wiggle for example
if there is a better way to do this please share…Thanks a lot again!
var expression1 = "wiggle (10,10)";
var expression2 = "w=wiggle (10,10);[w[0],w[0]]";
var expression3 = "w=wiggle (10,10);[w[0],w[0],w[0]]";for (i=0; i <= sellayers.length-1; i++){
for (p=0; p < = selprop.length-1; p++){
//missing query
selprop[p].expression = //expressionX;
Dan Ebberts
December 26, 2016 at 8:15 pmI think I’d do something like this:
var val = myProp.valueAtTime(0,false);
var numDim = val instanceof Array ? val.length : 1;Dan
Tal Arbiv
December 27, 2016 at 1:09 ami tried it and it breaks…
something about that valueAtTime method stops the loop that goes through the layers
var myComp = app.project.activeItem;
var sellayers = myComp.selectedLayers;
var selprop = myComp.selectedProperties;for (i=0; i <= sellayers.length-1; i++){
for (p=0; p <= selprop.length-1; p++){
selprop[p].expression =("1"); //WORKS GREAT
alert (selprop[p].valueAtTime(0,false)); // DOSNT WORK breaks the loop after the first layer
Dan Ebberts
December 27, 2016 at 2:11 amYou may have some properties selected that can’t have expressions, so I’d make sure that myProp.canSetExpression is true before doing the other tests.
Dan
Tal Arbiv
December 27, 2016 at 11:38 amThis will be great to add thanks.
but the problem wasn’t the expression. putting expressions works great for all layers and all properties, the valueAtTime line doesn’t.
what am i missing? -
Dan Ebberts
December 27, 2016 at 4:59 pmI don’t think you want to loop both selected layers and selected properties. This seems to work for me with everything I could throw at it:
var selprop = myComp.selectedProperties;for (p=0; p <= selprop.length-1; p++){
if (selprop[p].canSetExpression){
selprop[p].expression =("value");
alert (selprop[p].valueAtTime(0,true));
Dan
Tal Arbiv
December 27, 2016 at 11:38 pmwow, i was sure i tried that at the beginning…
maybe i needed some operation to be made at the same time to the layers… anyway, it works now,
really appreciate your help!
