Activity Forums Adobe After Effects how to change the position globally for many komps?
  • how to change the position globally for many komps?
    Posted by Timo Katz on January 8, 2012 at 8:25 pm
    Hello there,
    has anybody an idea how to change the position of 250 kompositions globally?
    there are 250 kompositions and I want the built up the possibility to set a specific position for all these kompositions at one time.
    is there any possibility?
    thanks in advance, Timo
    Timo Katz replied 14 years, 7 months ago 2 Members · 4 Replies
  • Timo Katz
    January 9, 2012 at 10:36 pm
    hello dave,
    thanks for your reply.
    the 250 comps aren´t nested into a main comp. they are all autonomic.
    and the footage placed in every single compostion needs to be moved for the same value.
    is there a possiblity to do this?
    best regards, timo
  • Timo Katz
    January 9, 2012 at 11:11 pm
    thank you, i´ll try that.
  • Andrew Somers
    January 15, 2012 at 9:24 pm
    You can do it simply with an expression – the expression below is placed in the POSITION field of the layer(s) you want to affect the position of, in each of the 250 comps:
    comp(“MasterPosition”).layer(“PositionLayerA”).transform.position
    Then you have one comp called MasterPosition, and a layer in that comp called PositionLayerA.
    Now, when you move PositionLayerA in the MasterPosition comp, all layers with that expression in any other comp in the project will move to match.
  • Timo Katz
    January 22, 2012 at 8:16 pm
    great! works fine, my thanks and best regards, Timo
