Activity Forums Apple Final Cut Pro Legacy How to change sync in different parts of a multiclip sequence
  • How to change sync in different parts of a multiclip sequence
    Posted by Radim Palus on May 19, 2010 at 11:46 am
    Hi everybody,
    I am having a trouble editing a multiclip. I got shots from two XDCAM EX cameras and one AVCHD camera to be used in a multiclip sequence. The AVCHD clips were split in 5 chunks and I converted them in XDCAM EX format and joined them i 1 long clip. Then I made a multiclip sequence and put the three angles in sync at the beggining. As I am reaching further, the angle from the AVCHD camera are getting out of sync. I guess there are probably missing some frames at the points where the AVCHD chunks were splitted. Now what to do? I don’t know a way to make a different syncing at different points of the sequence.
    Does anyone know any way to work this out?
    At this point it would be a little time consuming to start the project from the beginning but if there is no other choice I would do it.
    Thank You in advance!-)
    Radim
    Salvatore De blasio replied 16 years, 3 months ago 2 Members · 1 Reply
  • Salvatore De blasio
    June 3, 2010 at 4:54 pm
    hi,
    just create five different multiclip sequences after having your sync points changed on all master clips to keep them in sync. you should end with five different multiclip sequences.
    cheers.
    s@s
