Activity › Forums › Adobe Encore DVD › How to change subtitle aspect ratio from 16:9 to 4:3?
  • How to change subtitle aspect ratio from 16:9 to 4:3?
    Posted by Kriss Rozins on June 27, 2008 at 12:52 am
    Hi!
    A little problem I can’t solve…
    There’s a DVD project consisting of many subtitled timelines (subtitles are done in Encore, not imported as images etc).
    In the beginning whole project was ment to be in 16:9 aspect ratio, so I did all the subtitling in timelines set as 16:9.
    Now some timelines must be changed to 4:3 and this is where the problems start…
    When I change timeline aspect ratio to 4:3, subtitle text presses along (letters look stretched vertically). I need them to look normally (not pressed from sides).
    I tried different fonts and font appearing styles but nothing helps.
    Are there any tricks for solving this?
    P.S. I use Encore DVD 2.0
    Kriss Rozins replied 18 years, 3 months ago 2 Members · 2 Replies
  • Joe Bowden
    June 27, 2008 at 2:33 pm
    That is a tough one…
    Have you tried selecting all the subtitle clips, then changing the font in the Subtitle properties? And then change back, if you like.
    Does that fix it?
  • Kriss Rozins
    June 27, 2008 at 11:30 pm
    Nope – letters still stay stretched…
