Activity › Forums › Apple Final Cut Pro › How to change outline color in captions
  • Oliver Peters
    May 29, 2019 at 1:21 am
    You are describing closed caption files, not open captions, aka subtitles. Are closed captions what you want? If so, they have very limited formatting options, which vary with the file type (eg SRT, SCC, etc). The way the captions are displayed is also very dependent on the player – your TV, QT Player, VLC, Switch, etc. I don’t think any of these options include shadows or borders.
    If you want to turn your .itt file into subtitles, you will need a third-party app, such as one of these from Spherico:
    https://www.spherico.com/filmtools/
    – Oliver
    Oliver Peters – oliverpeters.com
  • Andreas Kiel
    May 29, 2019 at 4:49 pm
    As Oliver said, for Closed Captions there no real options to modify appearance.
    To convert FCP closed captions (SCC, SRT, iTT) to Open Captions e.g. Motion titles you can use my X-Title Caption Convert or X-Title Export.
    https://www.spherico.com/filmtools/TitleExchange/XTCC/index.html
    https://www.spherico.com/filmtools/TitleExchange/XTE/index.html
    Spherico
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
