Activity › Forums › Avid Media Composer › How to change length of subclip ?
  • How to change length of subclip ?
    Posted by Rosie Walunas on December 13, 2012 at 9:19 pm
    I’m sure this is really obvious…
    Possible to Trim or Extend a Subclip?
    Is it possible to change the duration/length of a subclip? Like to trim or extend its handles? How?
    Don’t necessarily mean in sequence, but more specifically that entire subclip. Have a bunch of logged clips, some need to be extended.
    Scott Clements replied 11 years, 2 months ago 5 Members · 6 Replies
  • Shane Ross
    December 13, 2012 at 9:43 pm
    Can’t be done. Have to make a new subclip.
    Shane
    Little Frog Post
  • Job Ter burg
    December 13, 2012 at 10:19 pm
    Can’t try right now, but if you can unlink and modify subclips you should be able to relink them – as long as you don’t modify past the master clip borders and as long as Source TC and Tape Name are the same.
  • Neil Goodman
    December 15, 2012 at 7:15 pm
    pretty sure you can put a subclip on a sequence and trim past back to the original length of the clip, if thats what your asking.
    Neil Goodman: Editor of New Media Production – NBC/Universal
  • Rosie Walunas
    December 15, 2012 at 7:21 pm
    Yeah, that’s it. Actually figured it out and if need to match frame have the choice to match back to main sub clip or master clip. That’s great to have the ability.
    Thanks.
  • Job Ter burg
    December 23, 2012 at 5:42 pm
    Not in a film project, though.
  • Scott Clements
    July 23, 2015 at 2:12 am
    For anyone looking for answer here. I’m in Media Composer 8.4 right now and can’t trim out a subclip in a 25fps 2K project. I have an action shot where sound man cut out early – resultant subclip makes it look as though the shot is over when there’s quite a bit left. I wish Avid would change this behaviour. This could be very problematic in reality television, I think.
    Film Editor, London UK
    http://www.scottclementseditor.com
