Activity Forums Adobe Premiere Pro How to change frame size/pixel aspect ratio in an active sequence? reen
  • How to change frame size/pixel aspect ratio in an active sequence? reen
    Posted by Dan Herlin on June 21, 2010 at 2:15 pm
    Hi, after starting a sequence and working with a bunch of clips I realized that the video format did not correspond to the settings I made when I started the project file. So now only part of the clips can be seen in the film. Is there anyway I can change the settings – I do not want the widescreen settings – or do I need to re-do what I have done so far in a new project/sequence?
    tnx
    Jeff Pulera replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jeff Pulera
    June 21, 2010 at 5:54 pm
    Go into current Sequence and use CTRL-A to “select all”, then create a NEW SEQUENCE with proper settings, then CTRL-V to paste contents into it from previous Sequence, that should do it.
    Jeff Pulera
    Safe Harbor Computers
