Activity Forums DaVinci Resolve How to change Frame Rate from Imagesequence
  • How to change Frame Rate from Imagesequence
    Posted by Felix Gorbach on August 1, 2012 at 3:45 pm
    Hello DaVinci Gurus,
    It´s so nice – after the softwaretraining one can think, that you are prepared for a real world job – and the grading works well – but there are some little traps I have to take – that was no question so far.
    I imported a OpenEXR Sequence wich was intended to be at 25 frames per second. But I don´t now why, DaVinci recognices that sequence as 24 frames. This is shown in the new Media Tag in Release 9 in the Metadata overview. And in the confirm tab I got the warning triangle, that there is a resolution conflict.
    The OpenEXR are at 720p, the settings in the Master Project Settings are at 25fps in the Video monitoring format.
    The option to calculate timecode is greyed out and set at 24fps…
    This issue is also in the deliver tab relevant. I can´t render a quicktime mov at 25 fps, only at 24 or at 23.98.
    So I´m sure that there is a easy solution for this.
    Thanks a lot – again 🙂
    Vasik Greif replied 11 years, 9 months ago 6 Members · 11 Replies
  • 11 Replies
  • Felix Gorbach
    August 1, 2012 at 4:45 pm
    Ok – sorry for this stupid question – found the clip Attributes by right klickin on the clip in the media tab –
    But my timeline is still in 24 fps and the settings in the master project settings are still nailed to 24 fps in the confom options dalculate timecade as 24 – greyed out no chance to edit this value…
  • Felix Gorbach
    August 1, 2012 at 5:00 pm
  • Felix Gorbach
    August 1, 2012 at 5:10 pm
    Frustrated from the greyed out “calculate timecode at” option I started with a new project and in the first setup I was free to set everything to 25 fps – the timeline works at 25 fps – the outputoptions are at 25fps as well – seems like everything is fine now – with the new project.
    But during the setup the 25 is greyed out in the “calculate timecode at” again. So I think that after a certain setup – you can not change the fps to another framerate?
    This would be sad for me, cause I graded my 24 fps project the whole day and this would mean, that I have to do the gradings again with the working project with 25 fps…
    Maybe there is an option to change the old project from 24 fps to 25?
    This would be great.
    thx
    Felix
  • Laco Gaal
    August 1, 2012 at 5:18 pm
    the Davinci manual clearly states that you have to set the “timeline calculated at” option before adding media to the media pool, or starting grading.
    Also there is a Davinci “lite” forum for questions like this:
    https://forums.creativecow.net/davinci_lite
  • Felix Gorbach
    August 1, 2012 at 6:20 pm
    this makes it clear.
    Tried some workaround like saving the working 25fps project as preset and using this for the 24 fps project – the existing 24fps timelines don´t accept the new presets. So it seems that I have to grade the session again – but hey – this gives practice and puts my eye in the future to the correct settings before starting to confirm stuff…
    thx for your help
  • Laco Gaal
    August 1, 2012 at 6:22 pm
    in the 24 fps project export all stills.
    open up the 25 fps project, and copy all grades for the clips.
    Or use colortrace:)
  • Sascha Haber
    August 1, 2012 at 7:10 pm
    The manual ALSO states it clear how to use Color Trace ™
    I suggest moving to the basic forum for now.
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • Jim Gilson
    September 8, 2013 at 1:16 am
    what a bunch of %#$####$
    “It’s OK. They’re speaking Chinese” – Firesign Theatre
  • Todd Sines
    May 9, 2014 at 5:45 pm
    Late response to this post, but figured it might help.
    There is no real elegant way to do this, but I found if you export a 24 FPS .xml from one sequence, and a 23.976 FPS .xml from another project, you can get around the blockade of not being able to mix media that were created at different frame rates.
    I opened my .fcpxml with TextEdit:
    XML header should have the following:
    You may have to either search / replace :
    conform-rate srcFrameRate="24"
    after the clip name seems to do the job.
    I had to do this with some DNG sequences that I had begun to grade in 24 FPS that I wanted to conform in an existing 23.976 sequence. Messy but if you're in a jam it can help.
    Todd Sines, director
    + SCALE : https://www.scale.la/
    New York, NY + Los Angeles, CA
    connecting the space between + within.
  • Felix Gorbach
    May 12, 2014 at 7:29 am
    Nice – thanks a lot
