Activity › Forums › DaVinci Resolve › How to change Frame Rate from Imagesequence
Vasik Greif replied 11 years, 9 months ago 6 Members · 11 Replies
Vasik Greif
November 28, 2014 at 6:50 pmI had this very same issue – at the end of a large grading session, I discovered my timeline was set to 24fps instead of 25fps. All the posts I found said “It’s not possible to change the settings”, but in the end, I managed to do that!
You need to go to your Resolve projects directory (here it’s C:\Program Data\Blackmagic Design\Support\Resolve Disk Database\Resolve Projects\), and open the project directory.You’ll see a bunch of folders and xml files. Now, you need to edit the XML files and search for some strings and replace these with some other values:
Changes I did:
project.xml:
24 ===> 2500000000000038400000000000000000 ===> 00000000000039400000000000000000
config2.xml
24 ===> 25
24 ===> 25sessions/some-code.xml
00000000000038400000000000000000 ===> 00000000000039400000000000000000That’s it! I have my project set to 25fps and I’m delivering at this frame rate..:-) Hope this helps – I don’t see a reason why this cannot be changed in Resolve directly….
