Activity Forums Adobe After Effects Expressions How to change Ellipse size to random number within range on second keyframe?
  • How to change Ellipse size to random number within range on second keyframe?
    Posted by Louis Hamwey on July 27, 2018 at 4:17 pm
    I have about 100 ellipses. I need them all to grow or shrink in size randomly all within a 50% range. I also need this to happen starting at 6 secs and ending at 8 secs with ease in and out. Ideally they start and end of the motion would be connected to Keyframes. I have scoured the internet trying to find a solution, but cannot figure it out. Any one have any ideas? Thanks!
    Andreas Brand replied 8 years, 1 month ago 2 Members · 1 Reply
  • Andreas Brand
    July 27, 2018 at 6:08 pm
    Hello Louis
    this code should work.
    Copy it to the scale-property of one of the elipses. Then right-click to the scale-property and chosse “copy expression only”.
    Then select all other elipses and ctrl+v.
    Hope that helps
    Andreas
    //This takes the markers of the comp
    var beginning = thisComp.marker.key(1).time;
    var ending = thisComp.marker.key(2).time;
    var shrinkFrom = 50;
    var shrinkTo = 150;
    seedRandom(index, true);
    randomShrinkSize = random(shrinkFrom, shrinkTo);
    var newScale = linear(time, beginning, ending, 100, randomShrinkSize);
    [newScale, newScale]
