Activity › Forums › Apple Final Cut Pro Legacy › How to change 29.97 timeline to 23.98 in fcp?
  • How to change 29.97 timeline to 23.98 in fcp?
    Posted by Richard Leko on June 13, 2014 at 4:07 pm
    Hi there,
    I’m in desparate need of some help regarding a project that i’m working on.
    All the footage for a music video was shot on a RED Epic in 1920, 2K, 3K & 4K at 24, 48 & 60 fps.
    All was cut on FCP 7, with Apple Pro Res 422 Proxy as the compressor in a 23.98 timeline.
    In the confusion of many sequences, all of these sequences were copied and pasted into an amalgated final sequence within the project.
    HOWEVER, for reason beyone me, the sequence setting in this FINAL SEQUENCE was set to 29.97 with the compressor of XDCAM EX 1080p30 (35mb’s / VPR). All the other sequences were set to Apple Pro Res 422 Proxy with the 23.98 timeline.
    I had only NOW noticed that this changed. My entire edit has been continued in this final sequence, and is quite elaborate with 15 video tracks.
    How can i change the timeline sequence settings back to what they SHOULD be, without screwing up my very complicated and finalized edit??
    When i attempted to copy and paste my timeline into a 23.98 timeline, everything was shifted, out of sync with the music, and not the right shots were used.
    Am I completetly screwed here?
    We only discovered all of this, after sending the project to my colourist.
    It was imported into his program fine, (RedCineX-Pro) but about 20 clips were missing. We removed the dissolves, but that didn’t help.
    After much frustration, we moved to Davinici Resolve, and that was fine…but the issue of the timeline setting differences were then noticed.
    In the end, i’m just looking for the following solutions:
    How to maintain the integrity of my FCP 7 final edit, and change the timeline settings from 29.97 to 23.98 as well as the compressor from XDCAM EX 108030P to Apple ProRes 422 Proxy.
    Any help in this matter would be greatly appreciated.
    Sorry for the ramble, but i’m read to pull all my hair out. Again.
    Richard
    Shane Ross replied 12 years, 3 months ago 2 Members · 1 Reply
  • Shane Ross
    June 13, 2014 at 4:36 pm
    Yeah, I saw this in the Apple forum. Sorry man, there is no way to change the frame rate. Compressor, yes, but the only way to get a sequence of another frame rate is to copy and paste into a new sequence…And do a LOT of fixing. Might want to do this when you are done editing…and get yourself down to only the clips you use in the final cut, instead of needing to fix many layers of video.
    Shane
    Little Frog Post
