Activity › Forums › Apple Final Cut Pro Legacy › How to capture from a DVD in to FCP?
  • How to capture from a DVD in to FCP?
    Posted by Digitalworkshop on September 27, 2005 at 1:06 pm
    I have to edit a Promo of making of a film song.I have the original DVD but how do i capture it into FCP?
    Pls do answer ASAP.
    thanx
    DIGI
    Digitalworkshop replied 21 years ago 6 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    September 27, 2005 at 2:19 pm
    Search this forum on the word “demux”… it can be done with a small piece of software.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mike Raff
    September 27, 2005 at 3:52 pm
    I’ve never done it myself, but I am told that a piece of software called Cinematize by Miraizon is the way to go.
    https://www.miraizon.com/products/products.html
    Mike Raff
    Richmond, VA
  • Liam Stephens
    September 27, 2005 at 5:58 pm
    I have to do it sometimes at work. I use a DVCAM deck and send the image & udio through using Svideo & RCA cords. U have to set the device settings in FCP to :non-controllable device”. Hope that helped
  • David Rowan
    September 28, 2005 at 5:12 pm
    I have a DVD player in the edit booth, just play it through the capture card, in my case an AJA IO. Quick and simple and looks great.
    DWR
  • Robin
    September 28, 2005 at 10:37 pm
    You could rip the dvd into it’s streams. Search on the net for DVD ripping software. If you’re on apple then mac the ripper works well, there are a bunch of others out there. Don’t use them for any copyright infringement though.
  • Digitalworkshop
    September 29, 2005 at 7:01 am
    hi!
    thanx to all of u replied.
    Is there no option built in FCP which lets u capture DVD directly in to FCP?
    i heard a plug-in(which is FREE!!) called MPEG STREAM CLIP.
    but i am facing a strange problem.May be the tool is not able to read the .VOB files properly or completely..?
    right when the sequence i need to capture/convert to DV/Quictime starts….the head in MPEG STREAM CLIP tool reaches the end.
    For e.g. the song in DVD starts at 26:03 and the song is in DVD’s file 02_05.VOB
    and the moment it starts the head reaches it end of the bar??
    and when i opened the 02_06.VOB hoping that the remaining would start automatically in it it show some other scene???
    so where exactly did the song go? i am sure it is in 02_05.VOB but it reaching its end in the tool???
    is there some limitation to this MPEG STREAM CLIP tool???
    pls…help..its urgent…very urgent.i have to start on this promo today.And yes no copyright issue as its a show on Making of video which became very popular.and since i am working for a channel they have taken care of rights issue before hand.
    Pls do help me out.Especially, someone who has used MPEGSTREAM CLIP plugin.
    regards,
    DIGI
  • Digitalworkshop
    September 29, 2005 at 7:02 am
    hi!
    regards,
    DIGI
