Activity › Forums › Apple Final Cut Pro Legacy › how to capture animation footage correctly?
  • Michael Sacci
    December 11, 2006 at 8:51 pm
    If they are on a tape they are 30fps so you would first capture them as such and the do the next step, if they are just files you can use compressor to export to the new codec and you can set the new frame rate.
